Is it possible to have a RAM Upgrade for Mobiles
Hi ,
I was just thinking will it be possible to upgrade LG P70 RAM .
I really can't afford to buy new phone , so if i can upgrade RAM form 512 MB to 1GB . IT will be great!
Это хороший вопрос?
Hi ,
Это хороший вопрос?
rahul razdan, the RAM is contained in an IC which is soldered onto the logic board. It is not possible for the regular DIY'er to change that IC. Unless you have a bigger RAM chip with the exact layout and ball grid array, and unless you know how to reball such an IC, it is not possible. Even if it could be done, the firmware might not access the additional memory address. Hope this helps, good luck.
Был ли этот ответ полезен?
oldturkey03 , thanks
The only way to have more ram is to buy a better phone I first had a free phone and had 512 mb. then I paid 49.99 and now have 1.9 gigs and still is not enough. Its like money the more you make the more you spend hense the more you need !? Go figure
Mere mobile ki ram kam hai increase kar do
Google Translate:
my mobile ram is low please increase it
Satyam Yadav, please read the other two answers to this question. RAM is always soldered to the logic board and is not user replaceable.
I want to increase the ram of my phone
@bluemoon46769 double check the answers. The RAM is contained in an IC which is soldered onto the logic board. It is not replaceable by the normal DIY'er. You cannot increase your RAM
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 917
