broken charger connecting(micro usb) port.
my galaxy note 10.1 is not working because it was broken micro usb port for charging. so where can I repair it in anchorage? or how can I repair it in anchorage?
Это хороший вопрос?
Это хороший вопрос?
Hi,
The charging port isn't soldered to the main board. Replacing is easy, because the charging port is on the flex cable. Look here step 15, pic. 2
Samsung Galaxy Note 10.1 Teardown
But you must have some experience to disassemble the Touch screen & LCD display module. It's held by screws and clips.
Regards.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 5,259
1 Комментарий
Good information here on teardown but does anyone have a suggestion on where to order the replacement port/dock connector? I've looked and I'm getting flooded with 2014 model info. Mine is the 2012 version. Thanks for anything you can share to help.
из Tony Perez
