The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
Why won't it turn on after screen replacement?
I just made a screen replacement on an RAZR and it looks like it won't turn on. I made the repair following the guide. When I plug the charger, a white led turns on. I tried to hard reset it and nothing happens. What could it be?
Это хороший вопрос?
Счет 3
1 Комментарий
I've double checked it and it's connected. When I try to reset it. The logo comes up but instead of start up it just goes black and nothing work.
из
Добавить комментарий
1 ответ
Выбранное решение
Have you checked the connections of the three display cables?
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Today another RAZR came in with a similar problem and the battery flexible was ripped. So it might have something todo with it too.
из
Question: Did you check the battery? Of the RAZR from your original post?
из
Добавьте свой ответ
Edgardo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 2,170
