The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
523вопросов Показать все
How do I permanently delete files from storage?
It says my memory is getting full. I have deleted a lot of pictures off my phone but when I sync's up to my computer all the pictures are still there. How do I erase stuff from memory that I already deleted?
Это хороший вопрос?
Оценка 10
3 Комментариев:
Yes its the same problem what i delete after few minutes all reappear again
How do i delete permeability
из
I want to delete the whole internal storage because if it is searched in the PC it all comes.
из
im needing to delete all the up loading ive put in storage. my phone is Galaxy S6
из
Добавить комментарий
5 Ответов
Open My Files and go through all the files, delete the ones you don't want
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
How do I open "My Files" - I do not have this on my display.
из
I've tried this, and the photos are still in my gallery.
из
I need to gallery's footed delete please help me
из
its in the tools icon on your phone
Оценка 0
You can directly delete unwanted files from your phone by pressing [delete] button on phone. If you want to delete them permanently without recovery, you can use Samsung data eraser tool.
Оценка 0
2 Комментариев:
how do I recover pic's that were deleted. My phone said that device storage was full. not sure what I did but all my pics are gone
из
You can use pro data recovery tool to get them back if they are not overwirrten. There are lots of such tools online, just search it online.
из
after deleting you should not sync your device right away. maybe the sync software have backed up the data you have before. you should check the back up setting on your sync software maybe get a new back up.
Оценка 0
it’s not an answer but a comment to “use file manager and delete from there” This did not work either when I went to gallery it was back. However I just read that after this you should off sync. for a while ??? A real pain it should be easier than this
Оценка 0
Добавьте свой ответ
midboe6 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 23
За всё время: 46,230
