Xbox One — третья по счёту игровая приставка от компании Microsoft, являющаяся преемником Xbox 360.
396 Questions Показать все
My Xbox One's fan is making this weird noise
Hello iFixit!
This one issue I am having with my machine. It seems my fan is making this whirring noise, but it doesn't sound like it's physically grinding on anything, but something sounds off, some described it as simply a cheap fan making noise, but I am not sure...I know MS support is usually the best way to ask, but they have been unhelpful as I have went through 3 systems with the same exact issue; MS support keeps giveing mixed reponses between "that is normal" and "send it in".
Seeing how you guys are experts in technology, I said why not give it a shot and post this haha.
Anyway, I have found a video with the EXACT noise I am having (and apparently others also) https://www.youtube.com/watch?v=jQaBr_xI...
I would really appreciate ANY input; whether is it normal or not, and should I worry about it, etc.. Thank you so much in advance, and again, I am such a huge fan of you guys!
Это хороший вопрос?
по рейтингу 8
Комментарии:
Is there a way to prevent my console from overheating because mine gets really hot.
от
before anyone makes this mistake (NEVER PUT A DRINK ON TOP OF UR CONSOLE)
от
Ethan Dyjak its normal to get hot if the top of the fan or console where the fan is is hot that is good it means its ventalating good its blowing the hot air out rather tahn keeping it in
от
Добавить комментарий
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
11 Ответов
Наиболее полезный ответ
It's most likely the console's system fan. Since it seems to be a common problem, I wouldn't worry about it too much, but if you're really concerned, there is a course of action that you can take. The first thing that I would recommend is lubricating it with a mineral oil, don't use WD40 for this. You'll need to disassemble the console to the point where you have access to the top of the motherboard, such as step 10 of this guide. I can't tell from the pictures, but it looks like you can remove the plastic fan assembly from the heatsink. Do that, and then use this procedure to lubricate the system fan. That should quiet the fan down and possibly extend it's life.
Был ли этот ответ полезен?
по рейтингу 2
Комментарии:
Actually upon some further inspection, I've found that you don't need to remove the fan from the heatsink. Just remove the black sticker on the top of the fan assembly and lubricate there.
от
Thank you so much for the answer!
Since opening it will break warranty, and I'm really not that savvy with any machines, in your honest opinion, do you think if I leave it be as it is, would it cause any issues in the future?
I asked around my group of friends and they all have the noise, and I asked around forums and even after getting a new unit/or their unit repaired, they said it still had the noise; making it a very common issue.
But, anyway, thank you so much for answering, much appreciated!
от
In your situation, I personally wouldn't worry about it. If the noise ever gets worse, then maybe it may be a good idea to look into repair. For the time being though, don't stress over it.
от
Hi guys
My one has been doing this since out of the box. Progressively getting louder. Now my unit started ticking and it litterly went poof. Not a joke. So I'm sending mine away
Just a warning if it's getting worse back up what you can and be prepared for the worst.
по рейтингу 2
Комментарии:
Did it make a wears nois mine did and I discontent it I am anly 10
от
Mine makes either a ticking noise non stop or it makes a noise of the fan but my Xbox is off
от
i think its the hard drive or something like that. thats what my dad said he thinks.
от
mine does the second part of corey cooks response.
от
something to try is turn the console off, then check all point of the power cable. blow dry then hover the vents on the power brick to remove all the dust. worked for me. just try and keep the brick well ventilated. also try blow drying and hovering the console just to be safe
по рейтингу 2
I had this same noise. So I gently tapped in the middle of the fan vent and it stopped clicking.
по рейтингу 2
My sons Xbox kept making this weird noise while he was playing it was driving me mad someone said it was dust on the fan so while he was out I cleaned it I got the hoover and hoovered any where I could see that there was and vent leading inside the Xbox and it worked for a short while so now every time I hoover up I go over the Xbox and since I’ve been doing that no whistling thank god because it was driving me mad
по рейтингу 1
I fixed mine (so far at least) by taking canned air and blowing out all of the built-up dust on the heat sync. I would also recommend doing this to the power supply and the kinect if you have one. But make sure the Xbox is turned off, doesn't matter how from what I've found, it's just the fan can’t already be spinning.
по рейтингу 1
Can someone help me. Mine makes a very loud noise like something is getting scratched even when there is no game in it. on certain games if I look in a specific direction it stops. It's very annoying my family even complains about it.
по рейтингу 0
my fan just whirrs really loud and it even does it when it is off. help please. ive had to unplug it at this point because it just wont stop
по рейтингу 0
Комментарии:
it is an xbox one s
от
i have an xbox one
от
I know what to do basicly you got to contact Microsoft and tell them to send a Xbox one shipping for free because your Xbox has a broke disc drive and it can't be solved by yourself and there is no way you can fix it that you have looked for forms to help you with it and it doesn't work pls help " say that and they should send you a Xbox shipping free in your mail so u can play Xbox again! It worked for me . Hopefully I helped you bro sorry you have to pass through that!
по рейтингу 0
At the moment over had some minor issues with my Xbox One s I've had it since Christmas 2018 and it makes a ticking noise and it's been like it for quite some time now
Plz if anybody knows anything about it plz comment
по рейтингу 0
I have this same issue too only its when I load up a game sometimes and the game doesn't exactly start. It makes a noise as if a fan was set to high and I’ve always thought it was weird but ignored it.
по рейтингу 0
Добавьте свой ответ
Lorenzo будет вечно благодарен.
Просмотр статистики:
За 24 часа: 77
За 7 дней: 363
За 30 дней: 1,847
За всё время: 102,291
