Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Repair and disassembly guides for food cooling appliances including refrigerators, freezers and fridge-freezers.
1247вопросов Показать все
Not getting cold at all
We have a 10-15 year old fridge that we moved from our lake place to home. It worked perfectly before we unplugged it to bring it home. It sat in our garage for about a week, we then plugged it in and it won't cool at all. The light comes on inside, but it isn't getting cold. I don't understand because it worked perfectly before we moved it? Any help would be appreciated. Thanks!
Это хороший вопрос?
Оценка 0
Добавить комментарий
The Essential Toolkit
The most helpful tools in our most compact kit.
Купить сейчас
Купить сейчас
2 Ответов
There are several possibilities the may be causing the problem.
Refrigerator's need to be on their on power circuit, if there is something else on the same circuit the fridge motor will not have enough power to run and may burn out. Or the outlet the fridge is plugged into may be bad. If you have a heavy duty extension cord you can plug the fridge into a different circuit, do not use a light extension cord it will not be able to handle the amount of power the fridge will draw and may catch fire.
If the fridge was laid on its back or side when it was moved the compressor may have been damaged.
The fridge is old the circuit board may have gone out, or the hard start capacitor may be bad. If the hard start capacitor is bad you should hear a clicking noise coming from the bottom of the fridge at the back.
Hope this helps
Был ли этот ответ полезен?
Оценка 0
Комментарии:
Thank you so much!
из
Evaporator Fan Motor
Оценка 0
Комментарии:
Thank you! We will check into this!
из
Добавьте свой ответ
Tammie Rothenbuhler будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 94
