Modern rebirth of John Cooper's classic automobile, made by BMW.
Cabin air vents not supplying any air.
I own a 2004 Mini Cooper S, and no air will come out of the dashboard air vents. All air seems to be vented through the defrost vents. I have checked all fuses, cabin air filter, and even tried the "off button/ '+' " system check with no faults found. Any suggestions would be welcome.
Это хороший вопрос?
Оценка -1
Добавить комментарий
Ответов (1)
Выбранное решение
Most cars have either a cable or a motor system to alter the air dampener valve/s.
When you alter the setting do you hear any noise of a motor or the thump of the valve closing? My Ford had foam rubber as a seal around the dampener door it got sticky so it wouldn't open.
You may need to locate the valves under the dash heater/cooler box. Try moving them manually.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Jay будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 1,443
