after cleaning printheads printer doesn't work and emits a beep
Hi, I dissassembled my printer twice after cleaning the printheads as initially it didn't turn on afterwards. After swopping one of the tabs around I reassembled it and it turned on. It began to clean and after a minute or so the light went off and now it won't turn on and emits a quiet beeping. What have I done wrong? I found the replacing of the tabs very difficult to see in which direction they should be inserted. Could I have put one back the wrong way round?
Это хороший вопрос?
10 Комментариев
See this post also:
Is my power supply broken?
из Garrett Min
I had this problem so I spoke with two experts. They said both your printhead and mainboard or out of work so they need to be changed and it costs a new printer. I sold my printer parts and bought a new one.
из Green Apple
Hi I'm glad to contribute to this forum with the solution for the problem when you change the printhead or you flush the printhead all of the sun in the printer won't start won't turn on what I found was that the two transistors on the hissing of the logic board fail I still haven't figured out why does the printhead shorts these two transistors but once you replace the transistors the printer toner design and gives no problems. Well no problems but it still won't print because I still haven't replaced the printhead I am trying to figure out why is it that the printhead is shorting out on the board because if not it will not work and it will short the board it again I tried it twice and every time is short the transistors so I hope this help you at least you'll get to turn on the printer again still waiting to figure out how to fix the problem with the printhead I am going to try with a brand new printhead see if it does the same thing Dario Ortiz Oss..!!
из DarioPCX
It would be of great help if anybody can get me the schematics of this printer with the schematics I can probably figure out why are these problems happening but without schematic is a little bit harder I seen they call him either schematic or diagram so if anybody can get the schematics of the logic board and all the electronica parts of the printer I will appreciate it thank you DarioPcx@Hotmail.com
из DarioPCX
I'm Sebastian having issue with Epson L3060 printer that is dead after cleaning it's printhead (ph). I'm sorry for my english.
Pritner is burned after i cleaned ph with cleaning solution, connected it into printer and run "ph cleaning cycle" from PC. It was silently beeping before it passed thru :( Seems there is increase of voltage passing to ph while cleaning cycle is run as normal printing did not burn anything despite short circuit causing Epson printing all colors at once during head alignment.
It results that transistors C6144 and A2222 might need to be replaced with F1 (or F2) fuse on main board. I read that all 3 components needs to be replaced in order to prevent power transistors to burn again (2 transistors + ph data cable + ph itself).
I have another one ph for L3060 that I rarely used, so will try with it after resistors replacement.
It has happen to me just yesterday. Today I'm going to disassebly printer to get into main board and do some measurements with multimeter.
Chears from Poland,
из Sebastian Susniak
Показать 5 больше комментариев
