2001 Buick La Sabre Limited's RPM gauge drops to zero while driving?
My Buick's rpm gauge goes from working just fine to 0 in a matter of 20min. The car jolts a little bit when this happens and used to turn off completely while waiting at a red light/stop sign/idling. Can someone help me figure out whats going on?
Ive replaced the following:
Spark plugs/wires, fuel filter, serpentine belt, MAP sensor, Battery (brand new and 200$), gasket seals, oil change.
Thanks!
Это хороший вопрос?
Счет 1
1 Комментарий
A faulty crank sensor can cause rpm issues along with poor running conditions!
из
Добавить комментарий
2 Ответов
Выбранное решение
When it "goes to 0," does the engine shut off, or does the car mysteriously recover and keep on working? Could it be a faulty ignition switch?
My Accord used to just randomly turn off while in the middle of driving, and it took me a couple of months to figure out my ignition switch was bad. I replaced the ignition switch and things worked perfectly since!
Был ли этот ответ полезен?
Счет 3
Can someone tell me why my 2000 Buick LeSabre speedometer not working RPM and Signal lights
Счет 0
1 Комментарий:
Did you get the problem fixed
из
Добавьте свой ответ
tarah буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 17
За всё время: 3,147
