UV loca glue as a replacement of double sided tape
Hello,
I've been running a repair shop in Belgium for almost 2 years now. I've been officially self employed since a couple of months, i've done every repair for all sorts of phones..
Lately i've been having some problems with the delivered double sided tape to use on iPads (to glue the screen on ..) the left side (where the flex cable is) comes lose 7/10 times, the flex cable pushes the screen out of its glue and come out ..Customers come back for this, obviously, but it's kinda a waste of time when i have to do 3/10 iPads again ...
I use doubly sided tape delivered by my supplier and i add another extra on sides which are known to come lose.
Now, out of a sudden i came to the conclusion that i need a replacement "glue" to think ahead and undo a problem.
I've been using UV loca glue (from ebay) to glue Samsung screens so I can just swap the glass...
Will this work on an iPad or to dangerous with al the cables and motherboard, etc...?
The glue is pretty stiff and not moveable without moving the phone around, so when i'm able to just glue the sides of the iPad (not to much) and widen it a bit then put the screen on and stick the iPad under UV light?
Not sure if it's a good idea, but the UV glue is very strong and doesn't come lose very easily...
Thanks ahead.
Это хороший вопрос?
