Repair guides and support for the sub-brand of Kodak consumer digital cameras, not including the printer or printer dock portion of the EasyShare line.
169вопросов Показать все
Why won't my Kodak EasyShare C643 power on?
I recently got a used Kodak EasyShare C643 camera. No manual, no memory card, nothing (just the camera).
I put in 2 new AA batteries and tried turning it on but nothing will happen.
Help?
Это хороший вопрос?
Оценка 2
Добавить комментарий
3 Ответов
Наиболее полезный ответ
How to power on my Kodak easy share c643 camera
Был ли этот ответ полезен?
Оценка 1
Hi,
Here you find the manual of the camera. Hope it helps.
Steffen
Оценка 0
3 Комментариев:
Nothing. I can't install the EasyShare software.
из
Have you tried step 1 of the trouble shooting? See here: Kodak EasyShare C913 Troubleshooting
из
Nothing happens.
из
I see this is years old but had the same problem with my Kodak camera. Finally figured out the battery indicator for how to place the batteries is very confusing. The +/- in the plastic at the top is actually is for the bottom of the battery not the top, so I had the batteries in upside down but thought they were correct. If you look closely at the metal plate that comes down on the batteries, you will see +/- indicators for the tops of the batteries. So turn your batteries around; it just might work. It did for me!
Оценка 0
Добавьте свой ответ
no name будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 30
За всё время: 2,022
