Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2201вопросов Показать все
water damaged iPhone isn't working after replacing and cleaning (isopr
I replaced the battery, logic board, cameras, speaker, antenna and cleaned the contacts or the whole parts in isopropanol over night. Let it 2 days for dry and put them together yesterday.
By connecting with my Notebook the connection/synchronisation was working. So I could see my music and photos. But the screen stayed black and I could not enter the pin.. While the connection the signal sounded constantly. Where is the problem? Do I need a new battery or new speakers? What can I do now?
Thank you in advance,
bne
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
bne, sounds like you need a new display. Of course, it is also possible that you have shorted out the backlight circuitry on the logic board. Start with a new display assembly and reevaluate. You mentioned in your question that you already replaced the battery, so no reason to replace it again.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
bne будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 73
