Sensitive screen after LCD screen replaced?
When making calls the phone will go on speaker or mute after the LCD screen was replace
Это хороший вопрос?
Это хороший вопрос?
This just sounds like it might jut be a faulty screen there's no way to stop it being to sensitive
Был ли этот ответ полезен?
This actually sounds like the devices proximity sensor isn't functioning properly.
If the screen were "too sensitive" then the issue would also be present when the device is away from your face, such as the reported ghost fingers issue.
Chances are the device requires a UV screen over the proximity sensor. Some devices, such as the white iPhone 4, must alway have this or the result will be exactly as you've stated.
If you need parts for your fix, I'm sure you can get them here at www.ifixit.com
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 270
