The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
170вопросов Показать все
Will putting in a new power supply cause data to be erased?
My Xbox doesn't turn on (Original Xbox) and I suspect it needs a new power supply board. If I repair it, will the data from the hard drive still be intact? Thanks!
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Silvercube, yes it will be.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Hi oldturkey03, just to confirm: the data won't be erased? I wasn't sure if you were replying to the question or how the question was phrased in my description. Thanks for your reply :)
из
That is correct :-) your data will not be erased.
из
Thanks so much oldturkey03. Repair stores don't fix Original Xbox anymore. I purchased a version 1.0 power supply board for my Xbox on ebay (hoping that was the issue) and opened my Xbox for the first time since we purchased it back around launch time.
Using the guide on the website and a YouTube video, I was able to put the new supply board in. When taking it out, I noticed my old power supply board definitely had got a bit burnt. After I installed it and put the Xbox back together, my Xbox turned on and everything is great again. All my data is still there like old times. Thanks again for your help! I'm so happy : )
из
Добавьте свой ответ
Silvercube будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 396
