The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318вопросов Показать все
Dryer won't start Error Code F70
Just had a Thunderstorm and lightning hit very close to our house blew 2 circuit breakers. I reset them and everything came on in the affected rooms. When my wife tried to start the dryer it wouldn't start and has an error code of F70 flashing. What does this mean and wan I fix it or do I need a technician?
Это хороший вопрос?
Оценка 6
Добавить комментарий
1 ответ
Выбранное решение
Doug, F70 means check harness connections at the machine control and at the console electronics. If your connections are fine to the machine control board and the console electronics, then you may need to change the machine control board. Unplug your dryer first and leave it unplugged for a while to see if it resets It is below the top panel on the left hand side of the dryer panel. I attached the tech sheet for the dryer to the bottom of this page. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 6
3 Комментариев:
I replaced a circuit board run as described "https://www.youtube.com/watch?v=eWqrn5kl...: However, I did not properly seat one of the plugs. I reopened dryerthe board and checked the plugs. Once I found the loose plug, I re-seated it properly and the dryer came up perfectly.
Thank you so much for this excellent video.
из
Thanks to this information above I was able to get mine going too!!!! (Thank you)
из
coding F01 is iqual a F70?
из
Добавьте свой ответ
Doug будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 13
За последние 30 дней: 64
За всё время: 34,780
