In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is call the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
210вопросов Показать все
CECH-4301c ps3 superslim 120volts can it be use with 220volts?
i have a cech-4301c ps3 model and i'm not sure if i can use it wiht 220 voltage?
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
rhy, "In a similar fashion to the PS3 Slim, the power supply is designed for inputs ranging from 100V to 240V AC, making it usable across the globe." you will not need a converter. from here. It is a universal power supply. All you need is a power cord the fits the outlet. the voltage on the outside label will most likely only display the voltage for the country it was sold at. i.e. US 110V. If you do want to make absolutely sure, you will have to open up your PS3 and take a look at the PSU itself. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
what i did was i plug it on 220 volts within a couple of minute once and its seems like there nothing wrong or smell burning on it so can it can be confime that ps3 cech-4301c is 110-220V before i will start a full game on it.. thanks for the replay..
из
The ps3 is dual voltage but you should confirm that by checking your power supply. First confirm that on the PS3 label is written 120 - 240V.
Оценка 0
I am planning to buy the Ps3 CECH-4301C 500GB version!! Bit confused about whether stepdown transformers are needed or not!!?? Can you confirm me here if this is needed or not to use it here in India.?
Thanks,
Siva
Оценка 0
3 Комментариев:
You will not need a transformer. the power supply is designed for inputs ranging from 100V to 240V AC, making it usable across the globe."
из
Thanks for your reply,
I was confused because, I saw the link for that model and in specification Box they mentioned "Power : 120 V AC, 60 Hz" this is what made me feel confused now :(
Here is the link for manual i saw,
https://www.playstation.com/manual/pdf/C...
Please do confirm if any of you have experience without using any transformers!?
What model did you run without transformers!?
Thanks,
Siva
из
Siva, Can you please confirm if it worked without transformer in india? I am having the same model
из
Добавьте свой ответ
rhy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 5,047
