Car goes in Safe Engine Mode afterTraction control failure
Traction control failure and Stability Failure warning lights come on, then car goes into safe engine mode.
The was a new trans put in less than 90 days
Это хороший вопрос?
Это хороший вопрос?
This or a very similar one was an issue on the old XK8/R (X100 series). The solution is to repair/replace the electronic part of the ABS module (Bosch/Teeves unit).
What is going on is that theres a motor or solenoid (cant remember which) that is soldered directly to the circuit board, and vibrations over time break down the solder joints. It just needs re-soldering. The electronic module is sealed so if you want to do it yourself you have to cut it open along the edge, do the repair and re-close it with silicon mastic. If you don't want to do it yourself there are companies that will sell/trade you a "reconditioned" unit for yours, which works out A LOT cheaper than buying a whole new ABS unit. At least on the XK8, if you're careful you can detach and (just barely) wangle out/in the electronic module without also having to drain/detatch/re-attach/fill/bleed the brake pipes going to the ABS unit. I've done it before, its not hard just awkward.
See this thread for more info:
Был ли этот ответ полезен?
What model does it concern?
I know that the XF 2.8D models get this message when a (completely unrelated) valve in the diesel particle filter fails, but this may be an entirely different issue.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 386
