How to remove a stuck screen
I know the video says the screen removal is the hardest part of replacing the battery, but mine seems more than "hard" to remove. I'm a 6' male and am using all my strength and the thing simply won't come loose. The iFixit-supplied suction cup keeps deforming and finally losing grip. Yes, I've cleaned both the screen and suction cup thoroughly to ensure good fit. The screen won't move. I guess being on there 2 years can get it "glued" in place. What tricks are there to force it to come off?
EDIT: In case anyone goes for the obvious, yes the pentalobe screws are removed. (They came out with surprisingly little torque.)
Это хороший вопрос?
2 Комментариев
The solution was to obtain a better suction cup. The one iFixit provides with the battery kit is insufficient to remove the iPhone 5 screen. Once I had a working suction cup I got the screen off in less than a minute.
из ktappe
Ktappe, I’m having the same issue with my iPhone 7. I see that it was quite a few years ago that you had this problem, but any suggestions on which suction cup to get? Mine is also insufficient.
из Lisa Anderson
