The ballast is no longer available & no replacement
I have a 2 bulb light fixture with Resi-tronic flourescent lamp electronic ballast 2003062 have .85A with a yellow, white & black wire coming out of one side & 2 blue,2 red, a brown and a gray wire coming out of the other side. The replacement ballast that I am told will work have completely different wire arrangements & I don't see how the wiring can be modified to work. Can you please provide an appropriate replacement ballast or a description of how to wire a different type ballast? Thank you.
update
Это хороший вопрос?
3 Комментариев
add an image of your ballast and/or light to your question. what bulbs are you using i.e.T5, T8 T12?
из oldturkey03
i sent photos directly to the address of your message but have not heard anything. I don't see a way to add photos on this site. Please help
из arch
Here is the ballast that I need to replace but is not longer made. What can I use?[image|411328[image|[image|411327][image|411325]
из arch
