After replaced screen, screen goes black during a call. Sugges
I replaced my screen and LCD. Double checked all connections during and after reassembly. Screen goes black and unresponsive during a call but seems to work fine otherwise.
Anyone come across this problem?
Это хороший вопрос?
2 Комментариев
may we disable Proximity sensor by any mean ??? because LG-G2 have no option to make it disable .. .
из bestengineer123
@bestengineer123 - you need the phone to be rooted. Install Xposed installer (you'll have to google it I think it's no longer in the play store), then install the "disable proximity sensor" module from within Xposed. Once you install it, reboot and your proximity sensor will be ignored (reading always far).
I had solved the proximity sensor problem by pushing the sensor a bit further into the case.. If I recall correctly I stuck a piece of folded up paper to it's back so it is pressed in place when I closed the phone.
из Kevin Compagno
