Sennheiser RS120 Wireless Headphones with recharging cradle
44 Questions Показать все
Why doesn't my transmitter turn on?
The green transmit lite on my transmitter doesn't
come on anymore to indicate the unit is transmitting.
It isn't transmitting. All connections are ok.
Any advice??
Thanks,
Paul Hipp
paulhipp@aol.com
Это хороший вопрос?
по рейтингу 8
Добавить комментарий
iPhone Battery Fix Kits
Only $29.99
Buy Now
Only $29.99
Buy Now
6 Ответов
Наиболее полезный ответ
I found this and incredibly it worked for me too!
Just use another power strip
"...I realized an extra device had been plugged into the power strip. It appears the strip may have been overloaded. Tried again with a new strip (careful not to load too many appliances this time) and the green light came on properly."
Был ли этот ответ полезен?
по рейтингу 4
Комментарии:
I tried every input signal and no dice, then I just unplugged and reinserted the power in the same strip. It started working immediately.
от
simple and effective solution. Thanks!
Who would have thought that a power outlet would discriminate power usage? (:
от
No green light?
Disassemble the transmitter and tap the crystal with power on. use non conductive tool !
The crystal is up front and has a shiny case.
I suspect a component value has changed and the oscillator circuit fails to start.
By tapping the crystal it starts the oscillator.
This makes the unit work until power is removed.
…or give the unit a sharp slap with the palm of your hand…that gives same result
..anyone have a circuit diagram to post? I may be able to determine the fault.
по рейтингу 1
Hey, I have same problem. Have you resolved it, at last?
Thanks,
Diego
по рейтингу 0
Комментарии:
hey, i have got the same problem
I contacted the service centre and they seem to solve the problem
от
We'd had a thunderstorm the other day and our house power flickered - that must be when it stopped working.
No green light with any input. After I unplugged the power supply and then reinserted it the green light came back, we were working again. Phew!
по рейтингу 0
i have an issue where the green light is intermittent at best and these are brand new straight out of the box
it doesnt matter which outlet i plug it into
по рейтингу 0
why cant i tune in the frequency on my headset
по рейтингу 0
Добавьте свой ответ
Paul Hipp будет вечно благодарен.
Просмотр статистики:
За 24 часа: 1
За 7 дней: 36
За 30 дней: 131
За всё время: 6,922
