My HTC M8 won't auto rotate how can I fix this?
I dropped my device and now when I try to turn it into landscape, it won't rotate.
Это хороший вопрос?
Это хороший вопрос?
Sounds like a calibration problem. You can re-calibrate the phone by going into settings. Then select "display and gestures" and choose "G-sensor Calibration". Make sure its on a flat surface, though, so it calibrates properly.
Был ли этот ответ полезен?
@Jose Estrada Still didn't work for me...
@Jose Estrada Nevermind! Restarting my device and then re-calibrating did the job!
WOW Thanks that worked perfectly.
I have the same problem, when i used your method it helped. Though when i want to move from horizontal mode to vertical mode ot just wont work. Any suggestions?
Thanks alot it's working hooowww
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 17,628
1 Комментарий
I am having the same issue and I haven't dropped my phone. My motion sensor stopped working on the lock screen as well.
из Matt
