Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4982вопросов Показать все
iPhone 6 battery getting hot during charging
I've been using an iPhone 5S lightning USB cable to charge an 5, 5S, and a 6 connected to a computer.
I noticed that the iPhone 6s' battery got extremely hot during charge.
Then, when the 6 was connected I noticed that it actually was draining the battery.
That same cable would charge the 6 normally when plugged into a wall socket.
I switched the cable to the new one that came with the iPhone 6 and it works normal when plugged into a computer. No heat and it charges.
Not sure if there is a difference in the new cables or not, but I did get caught out and had to use a 30 pin with a lightning connector. It sat plugged in overnight in a wall socket and did nothing.
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
i bought iPhone 6 , 2 days back but when i am using continue sly for 10 minutes it is getting very hot can anyone advice for it . .
Был ли этот ответ полезен?
Оценка 1
yes even my screen is cricked
Оценка 0
Добавьте свой ответ
donna будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 4,276
