Repair guides and disassembly information for phones from all manufacturers and service providers, including Apple iPhone and Samsung Galaxy. Get everything you need to repair your phone yourself.
73380вопросов Показать все
My infinix zero touch screen not responding, and wont power off
my infinix zero x506 touch screen is not responding to touch after system update
Это хороший вопрос?
Оценка 19
9 Комментариев
my infinix zero x506 the home menu not working even i reset the unit?
из
my infinix note3 start navigation icons on the screen not working
please help
из
my infinix note 3 pro touch screen does not work properly at the lower part what is the cause of this and is there solution
из
My infinix zero 4 has navigating icons and the screen is no longer clear what might be the problem
из
my infinix hot 6x screen is not functioning so how will I fix it and make it work again. if any notification comes I can't read the touch screen is not working so I need help please, someone should help me fix this problem.
из
Показать 4 больше комментариев
Добавить комментарий
8 Ответов
Наиболее полезный ответ
I have infinix zero 3 set and I got problem of screen touch not working and on searching on internet in XCLUB I got the way to solve this problem . The solution is Press power + volume up button for about 10 sec so that it may power off your phone then it will reopen with touch working correctly .thx for reading
Был ли этот ответ полезен?
Оценка 13
9 Комментариев:
worked like magic!
из
Mine is not working, pls help
из
wow, that was magic
из
very magic , magnificent
из
Thank you! Worked like a charm!
из
I have infinix Note 3 set and I got problem of screen touch not working for a day and on searching on internet in XCLUB I got the way to solve this problem . The solution is Press power + volume up button for about 8-10 seconds so that it may power off your phone then it will reopen with touch working correctly .
Оценка 5
1 Комментарий:
Mine isn't still working
из
After firmware update some phones required to reset. so try to hard reset device and check whether touchpad start to work.
Оценка 2
1 Комментарий:
I have tried to hard reset it still doesn't respond
из
I have infinix zero 4 set and I got problem of screen touch not working and on searching on internet in IFIXIT I got the way to solve this problem .
THANKS for reading
Оценка 2
i have infinix zero 5. my mobile touch is not responding. how can i fix this problem.
( The solution is Press power + volume up button for about 8-10 seconds so that it may power off your phone then it will reopen with touch working correctly) i have used the above step also still my phone is not responding
Оценка 1
1 Комментарий:
My infinix hot 4 pro power button isn't responding anymore, can't power off
из
Infinix phone is not passbook
work whote problem
Оценка 0
2 Комментариев:
Infinix phone is not unionbank m passbook
work whote problem
из
Infinix phone is not union bank m passbook
work whote problem
из
Àll the lower digits aren't working i.e *0# and done on my infiix zero 4. What do I need to do ?
Оценка 0
2 Комментариев:
Hello hi sir plz
Sir I am used me infinix hot 4mobil my problem help me disply not Working on and of sensor auto matic
из
I have Infinix note 30 but i can't power of or restart my phone in touch but phone touch is correctly working but power of or restart not working any solution??
из
Sir plz help me my mobile is this problem is the Sher me model numbar hot 4 x 557 plz solved my cellphone is on display not the of Every time on screen display on
Оценка 0
Добавьте свой ответ
obinna будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 65
За всё время: 24,140
