iMac 17" Works perfect only on Safe Mode
Picked up this White Imac 17" for $20.00, seller said Imac was dead....first boot went to screen with some artifacts and then it freeze. Try resetting PRAM and SMC...still same effects, I booted into safe mode and everything works perfect, no issues whatsoever, rebooted to normal, same issues as before. I figured that maybe a bad driver, so I started loading OSX Lion from my USB drive, everything looked fine during installation, no artifacts whatsoever, but when the final reboot to enter for the first time, back to artifacts and freezing....any help would be appreciated.
Это хороший вопрос?
12 Комментариев
Can you give us the last three digits of your serial number so we can correctly identify which model you have.
из Dan
VUX is the last 3 letter of the serial, the bottom plate shows to be 17in/2.0ghz/1GB/160/SD/BT/AP. EMC # 2114
из chrisimo
From EveryMac: This system can run the last version of OS X 10.7 "Lion" if upgraded to at least 2 GB of RAM. Although it has a 64-bit processor, it has a 32-bit EFI and is not capable of booting into 64-bit mode. It does not support "OpenCL"
из Dan
I would still try Snow Leopard Vs Lion
из Dan
Hi Dan... Thanks for your fast response... I did upgrade to 2GB RAM... Im installing Leopard into it as I write this from my ipad... Will let you know the outcome
из chrisimo
Показать 7 больше комментариев
