1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
139вопросов Показать все
Power on pads for Mid 2012 MacBook Air 11" A1465
I found information for a 2010, 2011, and 2013 macbook air but I can't for the life of me locate the power pads for the mid 2012 macbook air 11". Here are photos and I hope a kind soul would be able to assist me.
I've only tried the flat head screwdriver method at this point but realized it wasn't a solder point. Yes, I'm an idiot =P
Here's a photo of the board and I just marked locations where I think it might be located based on what I've read.
I figure if powers on then I will replace the keyboard but if it doesnt then it would also involve the logicboard in which case I wouldn't bother fixing it.
Это хороший вопрос?
Оценка 4
Добавить комментарий
2 Ответов
Выбранное решение
Asahi, here you go. Do not bridge any of the other contacts you marked.
Был ли этот ответ полезен?
Оценка 5
5 Комментариев:
OMG!!! This worked!! Thanks oldturkey03 =) I'm sure this will be useful for all the other 2012 MBA 11"with the same issues. Thank you thank you thank you!
из
you are welcome;-)
из
thx for photo, start my air after died power key button
из
You are FANTASTIC! do you know where the serial number for this board might be?
из
Diego V not sure what you mean by serial number
из
See this Answer - your case is similar. Use care shorting random pads on the logic board, you can kill it.
If this answer is acceptable please remember to return and mark it.
Оценка 1
Добавьте свой ответ
asahi21 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 9,738
