The Sony CFD-8 is a portable CD Radio Cassette-Corder manufactured circa 1998. It is one of the earliest models in Sony's CFD series.
6вопросов Показать все
Why won't the cassette player play my tapes?
I put the cassette in the cassette player, but it won't play. The volume is turned up.
Это хороший вопрос?
Оценка 8
1 Комментарий:
Can someone tell me where I can have a cassette player fixed?
из
Добавить комментарий
4 Ответов
I am not mechanical. Can you suggest someone near Ft Washington, PA or Ft Lauderdale,Fl who can fix cassette players?
Был ли этот ответ полезен?
Оценка 0
My NAD tape deck will not start. The power is on, when i press PLAY button it keeps knocking and knocking, tape rolls bouncy and knocks all the time. Once it managed to play and after that every time i stopped it and started PLAY again that was ok. After a couple of hours when it was switched off I tried again and knockings have come back and it won't set off.
Оценка 0
I also have a non working cassette player. Only had it fitted last week (second hand, not come back there) and it was working but now when I put the cassette in, the radio stops as it should but the cassette doesn't play and I can't hear the motor turning but it still fast forwards and rewinds so no idea. Gutted as it's a 1991 car and I don't want to put a cd player in as I prefer the retro originality of the radio cassette. Any help would be appreciated
Оценка 0
need a belt for the cassette player
Оценка 0
2 Комментариев:
Hi @joejefferson ,
If your device is a Sony CFD-8 then this link may help.
The 2nd answer in the link might be the quicker option.
Bad drive belt needs replaced
Here is one I found if it suits you and you're in the USA of course.
http://www.ebay.com/itm/SONY-3-356-345-0...
из
My cassette player is jammed and it's like the tape can't run through it. Then it sometimes unwinds the tape and it gets caught in the wheel. How do I fix this it's my dads and I really want to fix it ! Help please
из
Добавьте свой ответ
Tess будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 23
За всё время: 70,723
