Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68вопросов Показать все
Computer recognizes iPod, but Itunes doesn't
First, the iPod suddenly showed no music, but still showed that the memory was being used unchanged... Itunes wasn't working with the iPod, but still recognized it.
After recenting, memory used is back to zero and Itunes doesn't recognize, but computer still registers...
Any ideas how to fix?
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
It depends on your operating system... but format it using a utility you'd normally use to format a normal connected USB drive if you're system recognizes it. This will "corrupt" it.... iTunes will detect it's corrupted and prompt you to restore the firmware of the iPod... that might solve your problem.
Был ли этот ответ полезен?
Оценка 1
That did it, thanks!
Оценка 0
Добавьте свой ответ
Mike будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 1,040
