Released 2001 by Thomson multimedia Inc. The RCA RP3715A is a radio alarm clock equipped with AM and FM radio frequency reception, an audible alarm clock function inclusive of snooze, nap, and sleep settings. This device has a memory holding system which is powered by a 9-volt battery.
Why does my device produce no sound from the speakers?
No sound comes from the clock's radio function or the clock's auditory alarm function.
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
If your volume is on and you can't hear the device the problem might be with the speaker. The speaker might have a tear. Replacing the speaker and also making sure the wiring is properly attached should ensure that you hear sound. If the device rattles make sure the screws holding the speaker in place are not loose.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
joseph буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 14
За всё время: 774
