Why won't my phone turn on?
I put my phone to charge last night and when I woke up it was off. I tried taking out the battery, but that was useless. What do I do?
Это хороший вопрос?
Это хороший вопрос?
First check to insure your charger cord is not ruined. Many times this can be the main reason why your phone isn't charging. Try using a friend's cord or an additional one that you may have laying around. If this still doesn't work you will probably have to replace your battery. That is an easy fix! Hopefully that works, but if not your logic board must be replaced.
Был ли этот ответ полезен?
Heat the panel with paste if it dosnt work change the flex
when i turn on my phone it's say "error 507".what do i do ?
Open blackberry device manager on PC, connect blackberry device using USB cable without battery and continue repair option on PC with blackberry device manager.
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 21
За всё время: 3,049
me too I have the same problem, when I change my Sim Card yasterday, my phone did not open up to now
из ibrahimbas28
hi pls I need help with my blackberry torch 9810 which I got from someone. The next day I got a new battery for the phone and when I put it in it started blinking the red light and didn't stop I tried leaving the phone to charge but no solution even while the charger is plugged it blinks red light. I brushed the logic board with a solution and dried it. I was in the middle of trying to leave to phone to charge for 2 hours and then pull out the battery for 15 minutes before putting it again for another 2 hours. pls can someone help me pls I would be really grateful, thank u
из Evans Chibuzor
