The Saturn Relay was the first and only minivan from the Saturn brand of American automaker General Motors and was built alongside its sisters, the Buick Terraza, the Chevrolet Uplander, and the Pontiac Montana SV6.
29вопросов Показать все
noisy DVD player in 2005 Saturn relay
how to remove dvd player in saturn relay
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Наиболее полезный ответ
when u open the screen to watch a movie look at the other side and look up behind the screen there are 2 Phillips head screws on either end of the corners up there u take out and the dvd player falls down but be careful to go slowly and support it or it will fall down and pull the wires out of connector.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
what if the wires come out of connector is that a problem
из
what if the it falls down and pulls the wires out of connector is that a problem
Оценка 0
1 Комментарий:
When you say pulled out of the connector, do you mean that it pulled out of the DVD unit, or it pulled out from the connector in the ceiling?
из
Добавьте свой ответ
Eddie Dalton будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 2,421
