Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance. Released in 2012
doesn't display anything while sd card is on
After I used reemix 3-in-1 remote controle device on my camera it has stopped displaying any images or any nformation on the screen. but after I remove the sd card it shows my settings but I can't change anything else than shutter speed and apature vaalue.what's wrong withi it?
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
I have a similar problem. In M mode, when I insert SD card the LCD goes black until I change mode. The most of buttons don't seems to work but they're recognized (all of them wake the camera in standby mode).
Is there a way to change firmware in another than the classic way?
Был ли этот ответ полезен?
Счет 0
I had the same problem as you. Screen blank while memory card was in.
I had a third party grip/battery holder attached to my D3200 that had a cable that plugged into the camera and the grip to trigger the shutter. The cable was only partially inserted into the camera. When I plugged it in fully the problem went away.
Счет 0
I have the same problem with mine, £80-£140 for Nikon to repair, depending on fault. However I was told they suffer from fema faults, Nikon know about this, and will upgrade for free. Personally think it’s a nasty piece of rubbish made in Thailand with a Nikon badge on in it.
Счет 0
Добавьте свой ответ
ned буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 2,057
