Not detecting the battery
Hi,
I have a Dell studio 1555 laptop, Problem is the battery is not charging up . On further investigation I did the following
I replaced the new battery.
I bought a new charger (original)
I replaced the power jack with a new one
still its not charging could this be a faulty Mother Board?
Thanks for the help.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
As you are saying already had replaced everything it means there is problem with charging power unit into motherboard. So go to nearest Dell service store check by them. Never try to do anything by yourself in motherboard it may cause critical problem.Thanks.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
zasid будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 186
