If you are experiencing issues with the phone's microphone, try using the solutions below to fix the problem.
A common issue for this might be that the Mute button is on. Check that the microphone is not muted.
Test the microphone by connecting a wired headphone that has a microphone. If the headphones work while connected, remove the headphones and continue onto troubleshooting the internal microphone.
Test the audio by going to a quiet area and restarting the phone. Once restarted, record a new voice note by going to Messages and attaching a a recording to the message. You may also try and do a Skype Test Call. Skype is available from the Windows Store to download free of charge.
Finally, the issue may be a simpler one. Check and see if the microphone's opening is blocked. If so, use a dry cleaning cloth to wipe out any dirt or blockage.
Again, if neither of the above works, you may simply need to replace the microphone.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
How do I check whether my microphone is muted
из Hema
