Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
1004вопросов Показать все
Alternative to Power-On Pads when keyboard is disconnected
So I'm lucky enough. The spill seems so far to have affected just the keyboard.
I cannot boot reliably with the internal keyboard connected. I needed to pull the connector out.
With the keyboard out, I can boot using the power-on pads (by shorting them on the logic board).
For the time being, I'd like to use my macbook with external wireless keyboard and trackpad. This works fine, but I cannot turn the machine on, other than through the power-on pads.
Is there any other way to power a macbook up, with its internal keyboard disconnected?
Possibly, I can skip shutting down altogether, and just go into and out of sleep (since the trackpad will wake the machine up). Still, a proper shutdown before lugging the laptop is nice.
And while I have your attention, and since you have already read all the details, I'm also wondering: Is it possible to run the hardware test/(D)iagnostics through the wireless (bluetooth) keyboard? Pressing "D" during restart does not get me there.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Use energy saver settings to power on the machine at a set time. I agree transporting a running (sleeping) laptop is a bad proposition.
Probably not - but if you connect any USB (doesn't need to be Apple) keyboard that should work.
If this answer is acceptable please remember to return and mark it accepted.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Calaf C будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 81
