I can't see anything on my screen!
I am sure that the phone is on, there is even sound coming out from the phone but the screen just won't turn on! What is the problem?
Это хороший вопрос?
Это хороший вопрос?
You should first check if the battery has enough charge. you could also check if the LCD or the connecting cables are damaged. If the LCD is even slightly damaged the entire screen wont work.
Был ли этот ответ полезен?
If you reviewed all of that battery, screen and conexciones and all is well, the fault would be on the board, most of the time are one condesandor a coil and a diode that are serca ic lcd if anyone is injured or three screen not dara image
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 800
