Why is my backlight dim
How can i fix the backlight on my iPod?
Это хороший вопрос?
Это хороший вопрос?
anything happend to the iPod ??
how dim is dim ??
i would first try to reset the iPod, if that won't work - maybe the lcd needs to be replaced - but it could also be a coil inside the iPod - but those coils get mostly killed by shortings (fluid damage or the connector was shorted while changing the lcd (while the battery was still connected))
Был ли этот ответ полезен?
it was working fine - nothing happened to the iPod, I set it down, went back to it later in the day and the screen was dim - you can see the screen but barely -it still charges and works fine - is there another way of checking the lcd
did you try to reset it ? (press and hold the sleep and home button until the iPod restarts). what about warranty ??
same issue here. Not sure what's going on. Did you ever get it fix?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,477
