My hard disk need to repair
My hard disk does not appear in the Finder and in the AirPort Utility,the hard disk need to repair
Это хороший вопрос?
Это хороший вопрос?
Your between a rock and a hard place here ;-{
If you can't see the drive and the Ethernet/WiFi ports are working you'll need to take the HD out and drive connecting it via USB or FireWire port of your mac system.
At this point the you could try running Disk Utilities but any data on the drive will be lost as the format of the drive is unique to the Time Capsule. You should be able to format the disk for Mac OS and test it. More likely the drive is gone.
Был ли этот ответ полезен?
How connect time capsule hard disk via usb to mac!?
@HamidReza ShahriarZadeh - You'll need this Universal Drive Adapter Just remember you'll loose any data on it as its a custom format & file system.
Of course you have rebooted the TC.
Tried an Ethernet connected reset: ''
If there are physical problems with the drive, or cables software will not cure a hardware problem.
You need 3rd Party Mac Data Recovery Data software. To recover valuable data. Ones that I have found useful are Data Rescue 3, and DiskWarrior.
DiskWarrior can often resurrect mugged Master Directory Data. DiskWarrior is not a disk repair program in the conventional sense. It does not attempt to solve all of the possible problems that can occur with a disk. It specializes in eliminating directory errors -- the most common problems Mac OS users have with their disks.
Data Rescue 3 is the only utility that focuses on data recovery as opposed to hard drive repair.
Data recovery software must be run from another Mac, via a cable or the drive may need to be removed and placed in an external case.
If this answer is acceptable please remember to return and mark it accepted.
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 31
За всё время: 12,575
