Released in 2010, the Logitech G27 is an electronic steering wheel designed for Sim racing video games on the PC, PS2 and PS3.
43вопросов Показать все
LOGITECH G27 Racing Wheel
my g27 wheel has no force feedback and the shifter and clutch pedals don't work. The wheel works and all the buttons work. Thinking it might be the motor?
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Hi, Regarding your wheels lack of force feedback, it could be that the motors in your wheel are either broken or stripped. However I would check in-game settings to make sure before disassembling your wheel. As for the shifter and clutch pedal I can think of only two things that would make those not work. Either the potentiometer in the shifter is broken and needs to be replaced, or the whole setup is having a connectivity problem with your gaming device. The potentiometer can be replaced relatively easily however the connection problem would be much harder to find then solve.
Был ли этот ответ полезен?
Оценка 1
you're mum lol
Оценка 0
Could be the power supply.
Оценка 0
Добавьте свой ответ
meemo39 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 505
