solder a 01005 by hand .
Does anybody know how to solder a 01005 smd part by hand
Это хороший вопрос?
Это хороший вопрос?
Louis de Looze, 01005 is the metric package 0402 which is a component the size 0.4 x 0.2mm. To solder that, you will most certainly need a big magnifying source and great soldering skills. I recommend to let somebody do it that has experience in microsoldering (using a microscope while soldering) Take a look at this possibility. Hope this helps, good luck.
Был ли этот ответ полезен?
This type of soldering are quite common and easy to solder or rework. you can either use a solder paste or regular solder. i do however recommend someone to do it for you ..let me know if you would need my help in soldering this component
I doubt you're still offering the same assistance (5yrs later), but is there chance you might point me in the same direction of help?
.. in the same boat, w iPhone SE (1st gen/a1662), probably missing FL2400 (FL11) after recent pried batt extraction (damage)
You can put a wire there and it will work. If not, we can help you. Find ipadrehab.com and click Get Started. This is very straightforward with the right equipment and pretty affordable to send out for repair.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 490
