Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112вопросов Показать все
slow download speed to tablet
From super fast to slow at downloading any media on my tablet, relatively new, did a Chrome update the other day which may be related. Other devices in house ok?
Это хороший вопрос?
Оценка 2
2 Комментариев:
When was the last time you did a data factory reset on the device?
из
Never as hardly used it, how do i do this?
thanks
al
из
Добавить комментарий
1 ответ
Looks like al never got an answer to his question about how to do a hard reset for his Tab 7.0. Since the device is still around and every now and then there are some questions that pop up about this, the answer to this 7 yr old question is:
Ensure the device is powered off.
  1. Press and hold the. Power / Side and Volume Up button
  2. From the Android Recovery screen, select. Wipe data/factory reset. . Use the Volume buttons to cycle through available options and the Power / Side button to select
  3. Select. Factory data reset
  4. Select reboot system now.
  5. For completion sake only instead or archived
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
alan williams будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,068
