Отремонтируйте ваше устройство
Обучение ремонту
Магазин
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
80вопросов Показать все
Replacing a Magsafe "L" connector with a "T" connector
Hello All,
I own a late-2008 13" Macbook Unibody. I tried to replace the "L" connector of the Magsafe charger with a "T" connector following the instructions in one of the step-by-step guides in IFixIt but the result was not successful. Even when not connected to the Macbook, the light on one side of the connector remains bright green all the time while the light on the the other side is a faint green. When I connect it to the macbook the battery does not seem to charge and does not power up.
Any ideas?
Thank you in advance
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Best to just replace the compete AC power adapter Vs trying to fix the MagSafe connector. Most of the time the splice breaks down and the. Causes other problems.
Был ли этот ответ полезен?
Оценка 2
From your description, I guess you have a defective replacement MagSafe connector. In a proper working MagSafe connector, indicator lights are OFF while not connected to MacBook.
Оценка 0
Добавьте свой ответ
Dimitris будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 456
