Пятое поколение представительского седана Lexus ES.
How do you replace the cabin filter on a Lexus ES 350?
Dealers usually charge an arm and leg for minor stuff. I remember changing this on another car and it was really easy. The most difficult task is probably finding the filter itself.
Это хороший вопрос?
Счет 2
Добавить комментарий
5 Ответов
Выбранное решение
Here is an answer courtesy of hemicuda on RepairPal:
"the cabin filter is locate on the passenger side in the glove box. to get to it you must remove the shelf in the glove box by simply tugging it from the left side, then you will see at the back of the glove box a section that you can remove. once removed you will see a white compartment with a removable front, remove that and you'll see the cabin filter."
As far as finding the filter, your local auto parts store should carry it. Call your local Autozone/Kragen/O'Reily/NAPA/etc. and tell them the part you're looking for to see if they have it, or if they can order it.
Был ли этот ответ полезен?
Счет 4
2 Комментариев:
My garage charged me $49 for labor to change the cabin filter in my 2007 Lexus 350. I estimate the job took 5 minutes tops. Whate is your estimate of time for DIY for this job?
O.B.
из
I can't really provide a good estimate for this particular car. I will say that on my Saturn Ion it took me 5-10 minutes, but accessing it was very easy; there were no screws or panels to remove.
из
For most vehicles, it is located behind your glove box. Remove everything from the glove box, then you should be able to gently force the glove box to unhinge and behind it will be some electrical wires as well as the filter you are looking for.
Счет 1
For 2007 thrugh 2012 Lexus 350 GS the cabin filter is also located in the glove compartment. Same instructions to repair as 350 ES.
Счет 0
On the 2009 ES350 does it matter if AC is in recirc mode or not? Thanks
Счет 0
I removed the glove box and replaced the cabin air filter, but now after putting it back together, my glove box falls all the way out whenever I open it. It doesn't have a catch anymore to keep it from falling completely down. Can anyone tell me what I'm doing wrong with the side pins?
Счет 0
Добавьте свой ответ
gul буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 48
За всё время: 8,277
