Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630вопросов Показать все
Screen flipping out, typing by itself
My son dropped his iPad mini cracking the screen. The iPad still worked fine, he used it that way for a month. It then started typing and changing apps by itself and just flipping out. I assumed it was because the screen was cracked so I got a new digitizer from ifixit. I replaced it carefully using the repair guide. When I powered it back up everything worked fine for a while, then It started doing the same thing again. There seems to be no rhyme or reason why. It will work fine for 20 minutes, then start doing it even if is not being touched. If I power it down then turn it back on, it will work fine for a while, then do it again. Do I need to open it back up and check my work or do you have any other suggestions. Thanks.
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Выбранное решение
Hi Erickson,
Press on the bottom of the screen, left but specially right of the home-button. Does the ghost-touching (iPad working on its own) start then?
If yes, you'll have to open it back up, either 1/to un-pinch the digitizer cable (mistake during installation causes touch-screen cable to be pinched between the top glass panel and the aluminum frame/case underneath); 2/possibly to replace the touch-screen it if the pinched cable is irreversibly damaged; 3/possibly just to apply some Kapton tape to isolate some parts of the touch-screen from the rest of the iPad.
There are many discussions on this website/forum about how to fix those 2 issues. Here's a lead. Let us know if you need more help.
Polyimide Tape Изображение
Продукт
Polyimide Tape
$9.99
Был ли этот ответ полезен?
Оценка 1
I had this same problem on an ipad air. after i replaced the screen it became possessed, like someone was typing and opening programs. it worked perfectly with the screen laid in place but but when i installed it i put small cracks in the flex cables by not inserting them down in the case side and they got pinched between the screen and case .
so once cracked they can’t be repaired.
So i got a new screen but this time i kept the screen up on its edge so as not to stretch the cable .
then when you start to lay the screen on the ipad the cable tucks into the case space better.
same also when installing the display keep the display supported on its edge on you may crack the cables .
So that’s the fix for the possessed ipad don’t stretch or crease the cables
Оценка 0
Добавьте свой ответ
erickson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 11,656
