This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316вопросов Показать все
Charging for few minutes but won't turn on.
Hi.
My brother accidentaly got wet my DSL. It won't turn on. The LED turns green for 2-3 seconds, but DS doesn't do anything. When I set it to charge it's charging for 5-10 minutes and then the LED stops glowing. I've bought new battery, but it's not working.
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
hi
sounds like your motherboard has blown, this can be repaired but it's pretty tricky to do this - you'd be better off buying a second hand motherboard and replacing it
note though that depending on how much water got in there, it may have also waterlogged the screens as well - if that's the case then you'd be better off buying another second hand ds - they're cheap enough on ebay these days
hope that helps
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks! Yeah, they are pretty cheap. :)
из
Check the F2 fuse to see if its blown
Оценка 0
Добавьте свой ответ
Denis Bogdan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 198
