The Nexus 6 is an Android phone developed by Google and Motorola released in 2014 with a 6-inch display.
Can I fix my 3.5 mm jack? [pic]
Got a nexus 6 64 gb 3 weeks ago. The 3.5 mm headphone jack is not functioning properly. The problem consists of the audio being
1) very low volume and
2) distorted in a specific way; the bass and parts of the midrange seem to be missing.
The result when listening to news etc on radio is that some people's voices sound fine and others very low or distorted. Music sounds completely distorted.
This is an intermittent problem. I've tried using my regular headphones which work fine with other devices. They have a TRRS plug and a switch to swap between android and iPhone compatiblity although this setting does nothing in this case, sounds the same. When I plugged these in yesterday just to see if the problem was still there the sound was completely fine, problem gone. Later that day I tried again and the problem was there.
I've tried plugging in a pair of other TRRS-plug headphones which work in other devices with the same result.
Now, I tried plugging in another pair of headphones which have a TRS-plug and these always work. So if I plug in my TRRS-plug headphones, problem is there, switch to my TRS-plug headphones, problem is gone.
I can't figure out any other explanation than that the 3.5mm jack on my nexus 6 is broken.
Here's a pick of my plugs: http://imgur.com/FuqavHv
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
I can't say exactly what the problem is, but the 3.5mm socket connections on phones is not standardised and not necessarily compatible with stereo headphones, as an extra connection is required for the mic, which also often has to double as a connection for a button to pick up or put down a call. There's a good discussion of this which may help you understand what's going on with information about the various standards on Wkipedia - https://en.wikipedia.org/wiki/Phone_conn...
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
andy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 1,435
