The Asus Transformer Pad TF300T is an Android tablet computer released in April 2012. The Asus Transformer design includes an optional docking keyboard that “transforms” the tablet into more of a laptop computer.
Вопросов 20 Показать все
Why isn't the keyboard dock working?
My transformer pad is connected but i cant use the keyboard because it won't pop up i can only use the 'e' and 'l'key. Also sometimes when i connect the keyboard dock the screen freezes and shuts off and wont turn back on again.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (3)
I have the same problem. The "c" types in ";" the "x" types in "q" and the space bar doesnt wok. HELP ME
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
same problem. can someone help me pls
из
Make sure you haven't downloaded any alternate keyboards. If you have, disable all but one. Other than that, that's the only thing that helped mine. K0101......
Оценка 0
The last couple that I have repaired have had weird keyboard faults and they both turned out to be poor seating in the edge connector under the keyboard. Pull off the four rubber feet and undo the screws. Take out the two visible ones underneath and the three under the silver tab directly beneath the touchpad. Unlock the ribbon edge connector and clean the ribbon contacts.
It may be as simple as that.
Оценка 0
Добавьте свой ответ
Jennifer Hernandez будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 6
За последние 30 дней: 13
За всё время: 2,138
