What is error code 0xa000000e.
triing to reset to factory settings with acer recovery dics
Это хороший вопрос?
Это хороший вопрос?
That is a recovery install failure error.
You may need another copy of your disk.
Был ли этот ответ полезен?
I got another set of recovery disks from Acer, still having the same error code show up . I put my own password ln for f-2. how do I return it back to default setting? Maybe that might make a difference
I have a acer aspire to and i had the same problem i had corrupted or missing files try running a system scan i use sfc/scannow/f in the command prompt admin that will check your system files and repair broken or missing files also run a antivirus programm that worked for me.
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 423
could you post a picture or is this simply a popup Error:0xa000000e.?
из Goulithum
