Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630вопросов Показать все
Original touch screen is going crazy
Hi there.
I've got problem with my iPad mini 3G, yesterday everything was great but today my ipad starts crazy, screen taping itself like a ghost is using my iPad.
I tried this method Massive issues after Touchscreen replacement on different devices.. but I ave got original touchscreen and every tapes are on their places.
Tried to restore but it doesn't help.
Thanks for any helf.
Это хороший вопрос?
Оценка 6
10 Комментариев
hi, sofles i have this same problem on my iPad Mini, it seems like there is someone in the iPad but there isn't. I have restarted and restored my iPad Mini and it hasn't helped at all. so if anyone else has this problem and knows what to do plz leave a comment hear telling me because I am really fed-up with my iPad misbehaving. HELP HELP HELP HELP HELP!!!!!!!!!!!!!!
из
My iPad mini keeps going crazy too, and restarting it and holding the home and power button at the same time to restart hasn't helped either. It's really annoying and frustrating when it goes crazy and if anyone knows how to fix it or stop it from going crazy in some way please let me know. It would be very appreciated.
из
Have you replaced the screen before?
из
Never, screen is original
из
Yes, I replaced it
из
Показать 5 больше комментариев
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Does it have a cracked screen if so its the pressure from the glass
Был ли этот ответ полезен?
Оценка 4
2 Комментариев:
How do u fix that
из
Yes it’s cracked what can I do
из
sounds like my problem too, and I also have a cracked screen (which has worked fine for some time). It acts like there's a person or malware driving the iPad, but I think that's an illusion. No one wants to mess with my silly pad, I don't think any successful malware would either. More likely, it's caused by mechanical failure. Mine's an iPad mini, pretty old, been repaired before, I guess it's time. Like the previous person, I've always resented Apple for making their product so vulnerable.
Оценка 0
Hi I just had the same thing happen on my iPad Air 2. I did the reset, it has been working so far ( only been a few hours). You will lose your screen lock photo, wallpaper photo and more importantly saved passwords but that’s about it. Try the hard restart first then reset.
Оценка 0
Back up to iCloud, erase (wipe) iPad, restore from iCloud.
Оценка 0
https://discussions.apple.com/thread/248...
The above link may help you,
If it has helped please accept or score the answer thanks
Оценка -1
3 Комментариев:
Doesn't work for me
из
Okay, try to hard reset your device?
из
Tried. It looks like everything is ok when device is "cold" after reboot or long time of not using but after few minutes of using when ipad warms up touchscreen starts touching itself
из
Добавьте свой ответ
sofles будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 23,218
