Dear Daniel,
Does your tablet works if your battery is fully drained and your charger is plugged in? (= Does your tablet still works without charging and without using your battery?)
If so: might be a battery problem
If it doesnt work with drained battery
* or your plug isn't working, you can test this by plugging in your charger in another outlet
- or your charger isn't working, you can test this by using another charcher (same type though!)
- or your port isn't working
If you answer me we can figure out a solution together.
Kind regards,
Ruben
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
3 Comments
Kindly help me to get my problem fixed
из Kamala Borah
Dear Kamala,
Kind regards,
Ruben
из Ruben Debbaudt
I have tried three different chargers all are guaranteed to work with my Nobis 10” tablet. None of them work. Have tried every outlet in the house with the r3placem3nt chargers that are supposed to work with this tablet. The tablet won't even go on. I had not used the 5ablet f9r a while.wl4ked fine before this problem. What do I do now How do I get my tablet to turn on and boot up?
из fredzamora
